Final Cut sent to shake
Hello again!
I have a edited sequence on Final Cut (D1-NTSC-29.97fs).
I sent it to shake. Once my media has the pulldown fields,
I need to convert it to full frames if I want to scale or reposition
it as well. But I just can't do this (or can I?) on shake when
opening a sequence sent from Final Cut, because the editing
references are all lost if I do so.
Is there any other way to do this in shake using a script
exported from final cut? Or the only solution is to convert
the final cut project and media to 24fs, with no pulldown,
using the cinema tools, before send it to shake?
Thanks once more
Duda
