Findkeyframe Command
Hi!
Can't make work this code correctly
string $sel[] = ls -sl -transforms;
string obj;
  for($obj in $sel)
int $ini_f =findKeyframe -timeSlider -which next;
int $fin_f =findKeyframe -timeSlider -which previous;
        string $kfRange2 = ($ini_f+":"+$fin_f);
        print ($kfRange2+"\n");
there is few objects. Each of this objects have 2 kayframes in different frame. Objective is to get frames that have keyframes and insert : symbol between.
loop returns selections last objects values.
Find next keyframe works on a selection set. The flag -timeSlider is intended for the timeline view querry change so it can not be passed individual objects in bigger selection without wasting considerable time.
  string $obj;
  for($obj in $sel)
    int $ini_f =findKeyframe -animation objects -which next $obj;
    int $fin_f =findKeyframe -animation objects -which previous $obj;
  //select -r $sel;
PS: put code inside CODE
 and QUOTE
tags its a bit hard to show it in this foum properly because those tags turn into tags
Thanks Joojaaa !
I've just founded the solution too ) .
string $obj;
   for($obj in $sel)
select $obj;
int $ini_f =findKeyframe  -time 0 -which next;
int $fin_f =findKeyframe  -time 48 -which previous;
In this case I nee 2 value more. First one indicates 1 frame of time range and second one last frame but I choose yours
Its always faster to pass selections to the commands than to select and act on that. Because managing the selection s quite heavy thing and needs undo too and that wastes memory.
