First render in max....needs mass improvements tho
car model is a 2nd gen rx7, I just started using max like last week… so still very newbi on the materials and lighting and stuff…so any comments and suggestion welcome…
i took off anti-alia cuz it kills my rendering to like 30mins+ and I can’t wait that long.
nice work for someone new to max…ive been wanting to design a car, but i just dont know where to start, maybe u can give me some tips on where to start and the type of modeling technique
car was not modeled in max…imported from rhino3d, so sorry i can’t help w/ the modeling
Hi there
OK a few pointers on the lighting, which isn’t bad but can be improved. the most glaring thing is the number of hard shadows lurking on the floor around the underside of the car. That’s distracting and not very pretty. Try to make just one strong shadow to “fix” the car on the ground and keep the others soft and discreet. I’d also soften (ie blur) your one strong shadow just so it isn’t so razor edged.
The other area I’d look at is reflections. Most car shoots I’ve worked on have been lit by a big softbox suspended from above. This tends to cause a large white square reflection on the car (check out some car ads and you’ll see what I mean). Try adding an area light or just put a self illuminating white rectangle into the scene if you’re raytracing or make an environmental map with a white rectangle in. I think that will help “sell” the shot.
Good work, keep going
Andrew
