Fisheye Conversion
I am evaluating Shake at the moment. I am currently using AE 6.5.
I have a specific application I don't know if Shake can do.
I develope productions for planetarium viewing, a full 360 degrees. If you were to see a frame of this, the center of the square frame is the top of the dome, the bottom is the front, etc. Most of the work is done in a 3D environment with a 180 degree lens shader to accomplish this. I am able to use a plugin from Evans and Sutherland for AE called Virtual Projector to distort flat images/video to this "fisheye" format.
I would really like to start using Shake for some of its features, but it might be pointless if I can't map things to the dome.
Thanks in advance for any help,
DM
Try this:
LensWarp1 = LensWarp(0, "", 0, 1, xFactor,
2.5, 360, 288, 1, "100W@SC000VDhsuH9RYbMXJCm8QUPcJkW66fOfg6RZW5ERdL5aieam8xCNqGxiJnmfn25P0d6P55Ke2eO4WcQeX2reUP6O0X2Pef9UPQQw#caVHMk5bVV#DdZYJ5fVELMgQQEUcQgH2QgW1fdWa0QZEMOGaQ0QWQlONw93tSJAcAGtgaWwzfRTo05KMwUN4CCf5NVQ6nmk2TZT9Q3UcThCnzt28JDrFqOTzI8GpCrFBJ9qC#2@iKCGJiqIClCa4@2@iG4xG10C5aO61@2Y6ufDJu5650Gn5sCmG3s0m78EoAmT2xssxrTE0L4mOiHy76v5I0mUCN9NVUhpdmIO0@W@TRdbv3oSzzodx0ZQSMtE76x9SbGMpYW6pqVWB0Om6WilT0200Wge0000086");
I wouldnt look at shake as a replacement for after effects, they are made for entrely different tasks.
Thanks, I'll try it out.
Is that last parameter correct or did it not come through correctly? That's quite a long string.
QUOTE(mikemarcus @ 03/05/06, 08:31 AM) [snapback]230012[/snapback]
Try this:
QUOTE(dome_master @ 03/06/06, 06:16 PM) [snapback]230131[/snapback]
most shape parameters will look like this..
however, there's an encoding error that seems to happen if a <"> character is at the beginning of a new line (or a long string? not sure).. anyway, the first <& quot;> should read as a normal quoting character, ie <">.. (using the [ code ] tag usually helps the readability, but you still have to seperate the quotation marks).
LensWarp1 = LensWarp(0, "", 0, 1, xFactor, 2.5, 360, 288, 1,  "100W
++ christoph ++
