QUOTE(dome_master @ 03/06/06, 06:16 PM) [snapback]230131[/snapback]
Is that last parameter correct or did it not come through correctly? That's quite a long string.
most shape parameters will look like this..
however, there's an encoding error that seems to happen if a <"> character is at the beginning of a new line (or a long string? not sure).. anyway, the first <& quot;> should read as a normal quoting character, ie <">.. (using the [ code ] tag usually helps the readability, but you still have to seperate the quotation marks).
CODE
LensWarp1 = LensWarp(0, "", 0, 1, xFactor, 2.5, 360, 288, 1, "100W
@SC000VDhsuH9RYbMXJCm8QUPcJkW66fOfg6RZW5ERdL5aieam8xCNqGxiJnmfn25P0d6P55Ke2eO4WcQeX2reUP6O0X2Pef9UPQQw#caVHMk5bVV#DdZYJ5fVELMgQQEUcQgH2QgW1fdWa0QZEMOGaQ0QWQlONw93tSJAcAGtgaWwzfRTo05KMwUN4CCf5NVQ6nmk2TZT9Q3UcThCnzt28JDrFqOTzI8GpCrFBJ9qC#2@iKCGJiqIClCa4@2@iG4xG10C5aO61@2Y6ufDJu5650Gn5sCmG3s0m78EoAmT2xssxrTE0L4mOiHy76v5I0mUCN9NVUhpdmIO0@W@TRdbv3oSzzodx0ZQSMtE76x9SbGMpYW6pqVWB0Om6WilT0200Wge0000086");
++ christoph ++
