This may be a simple question but is there a node that effectively flattens your node tree like in Photoshop? Or do I need to export the sequence and then add effects to that? I am compositing keyed bluescreen with other elements and any time I try to add a general effect to the image it adjusts the keyed footage differently to the background images. Is this perhaps something to do with the alpha channel?
rendering out a precomp is the best answer for the question. Shake 4 will have a cache node that will "flatten" out what is above it to disk and read from that further down the tree, but one of the thing that makes shake slow with a large script, is that it has to reread the script for each frame, to work out what is relevent and what isnt.
Of course precomping only makes thigs faster that you dont have to revise, so be sure its probably not going to change.
The cache node prevents nodes upstream from being evaluated uncessarily. If I understand the original post, it seem as though the problem is not one of speed.
If you could provide a brief example script or a better explanation that would help.
