Does anyone have an idea as to how to have two flexlm liscence's running at the same time? i'm trying to run both softimage3D and maya without having to turn one liscence off and then start the other. i tried globetrotter but they were no help since i can't understand the language the program uses.
just use lmtools in the bin folder of one of the programs you installed not sure excately where it is but look around youll find it
and then just do configure services and have them both start on start up and use nt services
in LMTools, go to the last tab where you see the FlexLM manager info (for lmgrad, whatever etc paths).. Click on the box with the name of the FlexLM configuration, and just start typing a new one. When you press enter, you will have 3 blank spaces below to fill.. this is where you fill in your license paths for Shake, etc etc. Then, you can pull down the first box again to see the other licenses.
Sean
