no particularly simple solution to be honest, though you may want to try doing it by just using Maya Cloth with some animated wind fields or even a cylindrical volume-axis field that will effectively blow the cloth object along the corridoor (scale it so that the cylinder envelopes the hallway). Give the v.axis field a little turbulence so as to make the cloth sheet appear to fly around a bit. You will want to stiffen the cloth just a touch, so that it looks like paper, not a kitchen-towel.
Other than that, just rig the paper with a skeleton setup. If you put the root joint in the centre of the sheet of paper, and then add a few joints between the root and each corner, then you will have an x-shape skeleton that will allow you to throw the paper around and animate the roll of the corners. You cound even put in a cross shape, so that your skeleton now looks like the Union Jack (british flag) so that you could also fold the paper a bit in both directions.
