Hey all, I'm looking to create a simple script that will open a floating window inside Maya, and to have that window display a certain camera in my scene. Can anyone help on this?
I'm basically looking to create a separate window with a camera that will always be perpendicular to some facial controls I setup to a character I will be animating.
And I'll go you one more. Map this to a hot key to toggle the window size down to nothing or back up to whatever size you want. I have this set to my "d" key. Sweet!
int $tj_win_vis = (window -q -h tj\_window); if ($tj_win_vis > 50){ window -e -wh 1 1 tj_window; } else if ($tj_win_vis < 50){ window -e -wh 1200 900 tj_window; }
QUOTE(abigbeast @ 08/28/05, 04:39 PM) Hey all, I'm looking to create a simple script that will open a floating window inside Maya, and to have that window display a certain camera in my scene. Can anyone help on this?
I'm basically looking to create a separate window with a camera that will always be perpendicular to some facial controls I setup to a character I will be animating. [snapback]213582[/snapback]
If you ever wonder why repositioning the pivot is so hard for you its because youve actualy mepped the only key thet makes it a breeze to do since the way insert works is MUCH slower, in terms of usabilitu besides d is next to the snaps sia ll you need is d and v downa at the same time an milldclik and youve se the pivots location to vertex under pointter)
