Hello:
I am animating a dolphin by deforming it along a motion path using flow path.
I want to rotate the dolphin along its main axis as it swims along the path.
Before adding the "Flow Path", I can rotate the dolphin on the path animation by changing the "Twist" channels of the motionPath, but the rotation stops working once the "Flow Path" is applied.
According to the Maya manual:
However, I've tried this for both the object and curve lattices and have had no luck. In both cases, I changed the rotation values of both the Lattice and the Base.
Any suggestions?
Thanks.
