What do the tools do?
Thing is that 90% of any people requesting anything into maya is allready IN maya. Wich is why often even autodesk blows entirely looking into requests.
QUOTE
i was just hoping maybe it could be a script
I do not think you uderstand what scripting does. It can not make anything maya cant allready do out of the box. So scripting does not extend maya, its extends the user.
See maya can do a LOT of stuff outside what they have in menus, see mayas nodal and nodes can be connected in a unlimitted configuration. Some of them are very tricky, or timeconsuming to do by hand.
So 99% of everything maya can do out of the box, is undocumented, unconventional, never tough of and never used. This si not alimitation of maya docs,its literary imposible to document a unlimited number fo combinations. So for example having goo that flows on the wall completely doable but not documented because its just one of the more complex ways you can hook up nodes. Its self evident after a while but getting there is not so easy.
QUOTE
Somebody should close this wishlist board ![]()
Well you know most wishes are obsolete anyway, even on the autodesk suggestions 80% can allready be done.
If it was for me it would have been closed years ago.
