Fluids: banding and masks problems
Hi there,
I’m doing some 2d-fluid fog-type elements…
and I find it difficult to get a consistent density
and opacity distribution for all my elements.
The thing is that I have slowly and fast moving
fluids so I have very different density situations.
Playing around with emission density, the opacity curve,
density scale, adjusting internal and external lights (…)
were my way of tackling that issue.
I just find it difficult to adjust the values so that
I don’t run into problems with banding and mask
problems like too weak masks that produce greyish
looking fog (I want it more or less white).
The layers look pretty much ok in maya,
but imported in toonz it’s just a nightmare
(band’o’rama).
and i don’t think it’s the compositors fault…
So - if anyone can give some directions and hints
about the do’s and don’ts of density/opacity tweaking
for fluids especially in relation to compositing for film-
I welcome any answers!!
have a nice day!
martin.
doing smoke or glows, I always try to render them separately, like you are doing. Then I do one of two things. Either I tweak the mask levels in my compositor (which will make your banding worse), or I use a plug in from john knoll of ILM called unmult. It basically "unmultiplies the black from anything over black. It is one of the most useful free plug ins available. Not sure if it works in toonz, but you could always take your smoke into After Effects or combusion, generate your matte using unmult, then use it in toonz.
As far as the banding goes, did you try rendering a 16 bit iff file?
HTH,
mike
hi mike,
thanks a lot for the input!
i’ll try to fix the problem with the unmult-plug-in you mentioned, cool.
i tried some stuff on the weekend especially with one smoke element,
where i had bright and good color channels, but
a very very faint mask channel.
i couldn’t figure out why that was happening
(perhaps because of the high speed of emission
i had to do),
but my work around was just to apply a glow
that is animated to fit the different density values -
and voila, the mask was close to perfect.
there is still banding thou… but only in the mask
channel, i guess because maya just applies the
adaptive/jittered filtering to the color channels.
you are right - reworking the mask in compositing
made the banding even worse for this element.
so now i rendered the scene at double size,
and if i’m lucky the banding won’t show off as soon
as i shrink it down again.
i also thought about applying a little bit of noise to the mask in afterFx.
i agree also on using 16bit files - that will be my last
resort…
i didn’t think i would get such a helpful answer,
thank you for that!
cheers!
martin.
finally…
rendered it at double size,
added an animated noise in afterFx (more detail was good anyway), added like 3% additional color noise.
next time i think i’ll add the noise in maya with the
built-in fluid textures… thou it’s a bit slower then.
( but faster than 4k images, i guess ;O) )
cheers,
martin.
