Hi all gurus ![]()
I have a scene with oceanShader, 2 fluids and 3 directional lights. In the beginning I've set the scene to be rendered with maya software but for final render I need the ocean tesselation to be raised 8 times... maya gives me "Exeption ocured... not enough memory..."
In this case MRay comes
it handles pretty well the complexity of the ocean and reder is in acceptible times, the only problem that I have is that MRay doesn't catch light-linking relations for fluids in maya. I'm using only one of the lights on the fluids but MRay uses all lights and fluid gets overburn.
I'm not so familiar with rendering volumes in MRay, thats why I prefer to use fluid (it's easy to adjust for simple fog effects), also I found that with using real lights turned off the fluid can be used for very simple fog but selfshadowing doesn't work in this case.
Any suggestions will be great.
10x in advance ![]()
