Greetings,
How would I force a Shake-generate node -- say a text node, which has INFINITE length -- to look like a normal clip with a finite length? I've got some transistion operators that I'd like to use, but they require inPoint and outPoint to operate correctly.
Michael
Just open the timing properties of the text node (or whatever Shake-generated node) and set the inPoint and outPoint as you wish. They're set to -inf and +inf by default.
Well, yes, of course. I should have been more specific.
Actually, I was having a problem with a macro I created using the text node that was not appearing correctly in the time view. The node's name was listed but there was no bar to indicate its duration. Using the macro maker in Shake, I was making a simple macro to display a copyright/disclaimer screen that I use repeatedly. In the usual manner, I set up and selected all the desired parameters within the text node (including inPoint and outPoint) and then created the macro. The resulting node had timing properties in it, but changing them seemed to have no effect. And the time view still showed zero duration. Upon examination of the macro .h file, I finally discovered the problem... Shake had inserted an IRetime command with zeros for timeSlide, inPoint, and outPoint. Once I replaced those zeros with the variable names "timeSlide, inPoint, and outPoint" all was well.
Thanks for the response, Ivan. I'm learning that Shake can do some unexpected things sometimes.
Michael
