QUOTE(butcherhell @ 09/10/07, 04:40 PM) [snapback]273041[/snapback]
why enabling/disabling these buttons ?it should be always enabled .this wat not much user friendly.to disabling is not a really need
They are only enabled when you have activated a tab that has a step by step zooming, for example work area or disk type tab have free zoom so they aren't included in this list. To be honest id disable the entire row its of no use (waste of space) but many users are way too icon centric to permit this. (personally i liked them more when they were free zoom types, but this was a top 10 most requested change!)
This is not a bug, its very intentional, as at least disk tabs (they are visor controls), don't have a way to control this, so because it wouldn't do anything you'd need to use it.
Anyway i understand what your saying, since you only have the non zoom able swatch on, so it should only disable if someone chooses a panel INSIDE the panel thats of in accetaptble type, so just because your in model panel it shouldnt disable. That could be done but its much easier to make code that impregnable if you make it act on all changes as opposed to just some changes. But the really hard partis this:
See its a SUB tab specific option so the SUb tab you have active defines if its on or not. Now you can have several differently said tabs in hyper shade, worse yet 2 of them active at the same time, how then would the user know wich one hes acting on because its not visible for him in any way? Then theres the odd case where theres only one settable visible, But yes this can be done. Its just not necessarily less confusing, it can indeed be even more confusing. Atleast now its easy to spor the whys when you put in all the 4 special clauses its no longer so evident. (herein lies the prblem of good guis you can do it better but then ist no longer readily apparent making it worse on other aspects)
So theres really need for it to disable for user experience consistency. Because otherwise youd be wondering why its sometimes no on and sometimes is, an wy it sometimes affects this tabe and sometimes that. So the only really consistent is to omit the buttons and go back to using rmb menus (but again thats bad for reason that some donet never gind those menus and they are supper cluttered)
So wich one is the perfect never annoys anyone solution then But yes i can fix this for you.
