Hello, I
Why do you need them?
ww
This is just how maya works. You cannot just have points in space with maya. Only way to keep track of points in space is to put a dummy node(locator) in the same spot.
No but you can creae particles that would be almost the same. Do this:
make the object in question a softbody.
duplicate the particle object and then delete the softbody. (or rearanging the structure and deleetng the box should work fine too).
