oh yeah there's a node you need to add .. for some reason the connection does not input the vales as you'd expect. If you keyframe it and then look at the channel in the graph editor the calues are very small but if you edit the channel there it's what you'd expect.
Lemme see if i can recall which node you need otherwise you shoudl just set keyframes and then edit the channel in the graph editor
