i have a problem where the friction between 2 colliding objects is too much (they stick together after collision) but if i decrease the friction factor then they slide too much on the ground (passive ncloth).i have maya 8.5 sp1 now.any clues how to make them separate after collision??cheers
You could use low friction on the two objects and high friction on the plane object. (or the nucleus ground plane, if you are using that) If it is sticking due to interpenetration then increasing substeps might help.
Duncan
duncan your a star, thanks for that. it was the interpenetration & increasing the subsets worked.
