Ok, I’ve managed to create a 3d model in Maya. My goal is to animate the model, and load that animation into a video like they do in the movies. I know this probably a stupid newb question, but I browsed the forum and googled and couldn’t find a tutorial quite at my level. WHat I’m doing is creating a monster and animating it to walk around and then drop on my street while actors run away. Please help and don’t flame!
If you want it to do the simple, yet WRONG way, and you are rendering with maya software, then open your render globals and there you will find output format settings where you can pick .avi, if you want to do it right and/or you are using mental ray, render out sequences of images and then use some post production software to put those frames into a video.
I undertsand how to do that, and I’ve managed to do it already. It’s the part about loading my video into maya that I can’t do. I want to be able to see my video in back of my monster as I’m animating it. Also: How would I hide a part of the things body, when, say it should be partially obscured by a wall?
I dont know how to import video into maya (im sure its not that complicated). To hide parts of your character that are behind some parts from the video, i think its best to do it in post production using z depth in programs like adobe after fx, combustion etc…
I figured out how to load my video in. You were right, it wasn’t complicated. As for hiding things, I’ve also managed that with a little help from Maya’s help files. Now what I need to accomplish is making my model look like it fits the scene, such as blurring it and adding lighting. I do have Adobe After Effects, but I think it can be done in Maya easier (plus I don’t know how to use that program very well either). If you know how to do this, please let me know.
Actually you should match the camera in maya or a matchmover (or maya live), use the imported image as reface ONLY. then grade and mate the images qualities in post (in your case AE), it allows you to work much faster and more precise.
You can also use Boujou, wich is a tracking soft for video and then import yor track in maya
