Hello. I'm a new NUKE user coming from Shake.
I have a question about the Time Shift.
I have a project with 500 frames.
Now I read a sequence (1-to 90) but I need to shift the frame 1 of this sequence to the 200 of the project.
To make this I have used the Time Offset but I have a problem.
In shake the Time Shift translate the first frame of the read sequence to the desired number (for example 200). Before this number I don't see nothing of the readed sequence.
In Nuke I'm able to translate the readed sequence to the desired frame (200) with the Time Offset node but before the frame n. 200 I see always the first frame of the readed seuqence.
Where is my error?
Thank you in advance
