Full Body IK (3)
Now that Maya has placed in Full Body IK, are you guys going to use it? Will you use controls along with it or use the flexors since you have to pin joints?
Thanks
I just rigged a character with it. Very simple and powerful. Only now I'm trying to understand more about final setup - and how to use the effectors along with extra - non FBIK joints and and IK (like a tail, and mouth).
I'm also looking for tips on using control objects to trans/rot the effects, because the effectors are all at non-zero trans/rot.
the FULL BODY IK looks good,but how do you set the wrist twist?do you have to manualy hook up or remove the X rotation from the forarm so that only the armRoll will twist?
Any ideas?
I'm not so experimented, but the fbik control and skeleton should drive extra non fbik joint or control via some constrain, driven, expression,....
A fbik join chain could drive an other join chain with different chain topology.
For the form arm, you could simply associate a new join chain with a form arm splitted, and by skinning ->option->use selected join, to use the good chain.
But I'm not so experimented....
But it look great this new implementation of motion builder technology, with some more customisation it will be better....I've just downloaded the fbik creation tools from the script download page...
Apparently there is a workflow for including auxillary joints for ulna rotations etc into the FBIK setup. I have only found reference for the naming of the aux joints in the docs but no instruction on how to actually assign the joints as part of the FBIK rig. It seems that you need to do this using the joint name workflow, but I prefer to name my joints using other conventions and have opted for the joint label option, which doesnt seem to allow the addition of the secondary joints... still dycking around with it. Tried adding the rotator cuff nodes after iinitial fbik setup but nothing. Sigh.. guess I'll have to rename all joints in teh skeleton to get to the bottom of it.
Does anyone out there know how to add these joints into the rig? basically I have created the skel, labeled all joints and run the fbik setup.
BTW the rig seems good but deleting animation off manips can result in some strange results..
Gerard van Ommen
Animal Logic. Sydney
open the 'hikHandle1' tab in attribute editor, reveal the 'Roll Attributes' under 'HIK Handle Attributes' and check the 'Left Fore Arm Roll' option.
