QUOTE(concepts21 @ 11/29/06, 05:46 PM) [snapback]253593[/snapback]
I know what you mean but when I click on the add item or the map item nothing comes up? should I get another window or something else?
Yes, you should select the geometry on the assigned surfaces section of the fur description tab.
It is just under the global scale of the fur inside the attribute editor. Every time you want to map something directly on the details you will have to select the geometry first.
Cheers
