Posted 09/18/06, 02:18 PM
Hello Friends,
I am rendering a character moving thru a fluid cloud, but need the fur on his head to be rendered as a blackhole with the Character. Is this possible? A million thanks.
drBlacksnake Members
Posted 09/18/06, 08:55 PM
why exactly blackhole? render just a head and then use its alpha as a mask.
bjohnston Members
Posted 09/19/06, 08:35 AM
Hi,
My character is walking thru some billowing 3d fluid smoke and I am rendering the CH separately. The alpha of the hair is solid and I need the character to pass in, out and thru the smoke. When I apply the blackhole material to the model all is good--except the hair-so I need the charater and his hair held out (blackHoled) so it looks right in comp.
Maybe I can make the character and hair white amd make the fluid completely black and render an "alpha" pass that way?
Posted 09/19/06, 01:23 PM
You dont need to change colors. delete rest of the body and do usual render - extract alpha form it and do compose.
bjohnston Members
Posted 08/28/07, 1:03 PM
Hello, you are not understanding my problem. I do not need a solid alpha. I need a hair hold out within the fluid volume, with varying thikness of smoke. The smoke is swirling around and thru the hair, and a solid matte will not work. Any other suggestions? Can I convert the hair to polys? thanks for any HELP!
