Fur rendering in mental ray (2)
when rendering fur in mental ray, this message show up in output window.
PHEN 0.7 warn 052009: running out of stack space. shader failed
repeated
no matter how i tweak the density of fur, it happens every moment when rendering the specific model.
what drives me mad is that the message doesn't show up to other models applied the same fur description, even though they've got more polygons and more density.
so i don't wanna think that is matter of memory or CPU.
what shall i do?
hoping your kind advice.
Is there anything werid in the geomtry of the object that would cause a memory leak? I'd check the geomtry of the object applied and make sure is clean, look for any oddities. That might be something to try.
You might be right, but it happens when i attach the fur description to a default polygon mesh, even though the warning lines gets shorter. It doesn't seem to have any regular error rules.
thanks anyway!!
