FX500 or FX1000?
is it worth the whole extra wad of cash to get a FX1000 over a FX500?
I own a FX1000 and recentl;y have useda FX500 and I am glad I got the 1000.. IT is particualrily faster when workng in wireframe mode but in general it seems much faster than the 500.
However if the extra $$$ for the 1000 is breaking your budget you coudl do well enough witht he 500.
thats all i need to hear thanks =]
I would say that it’s depend on your application:
under Maya after benchs i’ve seen both are pretty close, under Maw it’s another story.
anyway the 500 is a killer card for this price range.
The new FX 1100 is cheaper and faster than the old FX 1000.
if you cna afford the 1000 get it.
Its a wonderful card for the money.
I have no yet messed with the 500, but i do here its a great card on a budget.
fx1100 specs look worse than the fx1000 though
but im gonna probably get the fx1100 it looks good
yeah, picking up the fx1100 too - looks good for the $650.
any word on qualification with maya 5 on this card? should behave like the other quadroFX’s, i figure same driver and architecture right?..
better compatibility with 2000pro or XPpro?
replacing my sketchy firegl8800 (curse you ATIIIIII !) freaks out with directX9 on 2000pro
Note that NVIDIA is trailing ATI’s newer cards a bit in DirectX 9. ATI trails in OpenGL. I’m not a gamer, so NVIDIA is an obvious choice, but don’t ignore ATI if you want good DirectX performance.
I was curious why the 500 is said to run slower than the 1000. Does it actually take longer to generate a rendered image with the 500 or something becuase i thought only the cpu was responsible for that.
Well, basically what are the major differences performance wise between the two cards, and is the 500 not perform particularly well or something because I’m getting the impression that there is a world of difference between the two (as if it would take 10 times the time to generate something with one card compared to the other)
Generally speaking, the video card is responsible only for displaying the images you see on your monitor. When you’re working in Maya (or whatever program) and moving objects in 3d space, the card must compute every frame. For low resolution work without a lot of textures, etc., just about any modern card will do. But when your scene gets heavy, with lots of geometry and textures, the slower cards begin to lock up and stutter with very low frame rates. The benefit of an FX 2000 or something is that you get much better performance in heavy scenes. The FX 500 (which I have, by the way) is slower under extreme conditions, but more than adequate for most normal work.
As for rendering, Maya now offers hardware rendering using programmable hardware shaders. The Quadro FX line supports this feature, but GeForce cards do not.
here’s something that might interest you:
http://www6.tomshardware.com/graphic/20030916/opengl-20.html
these are the overall comparison results after fx3000/fx500 tests (with some ATI cards) and the fx1000/fx2000 test is here:
http://www6.tomshardware.com/graphic/20030305/index.html
hope this illuminates things
/risto
btw: I use fx1000 (with maya) and I’ve been very pleased with its performance
