Game levels are tile based textures still?
anyone can tell me if most 3d game level developed today still use tilable texture in them? I mean shared UV space for textures.
if so than how is that possible that I see some games use light maps in levels? are they not huge memory hog, i persume they are full textures no tiled light maps.
the reason for this is simple.. one does not waste as much uv space… also its less costly to loead 10 512 textures than 40 256 textures in general.
The light maps are just baked on uv… nothing more and since they need to be loaded once… besides on can get away with pretty low fidelity on this count most of the time.
it depends on context.
what target? (hardware platform)
what framerate?
what type of game?
memory management.. etc..
some games have tried procedural textures, and some work, some dont, there is still a mix of procedural and filetexture based hand texturing tho..
procedural textures are generated at runtime by a programmer and his algorithim. (sp?)
I dont know of anywhere that uses maya procedural shaders directly in a game engine..
It is a nice idea, but the following might be a problem;
it (procedural texturing) is a very expensive (cpu time) effect to do.. and AW guard their algorithims like crazy..
it’d be hard to match the runtime aglorithims with the maya generated one for the above reason..
wrt to light maps- some games do another pass, others use a "subface"technique to blend a “shadow” over the base material..
there are lots of ways and means to explore light maps.. these are only two.
look at MGs3 for some amazing light mapping, it wouldnt suprise me if a lot of that games backgrounds were textured procedurally in maya, then a convert to file texture used…
hope this helps a little .. its a real pandoras box of a subject..
