Hi
I have the choice between FireGL1 or geeforce2 to run maya 4. I use currently the FireGL1 and ime satisfied. Could you share some experience with geeforce2?
i have a fireGL1 in my old machine ive had for 2 years and its served me great, still does. maya performance over all is much better on the fireGL1, but you cant play many games on it either. geforce2 im sure can push a few more polys but hardware overlay planes are really bad especially in maya.
qoute from alias wavefront hardware certification page:
“There are many cards based on GeForce256, GeForce2 and GeForce3 chipsets. nVidia and Alias|Wavefront do not recommend these cards for use with Maya 4.0 as you may experience various refresh, display and stability problems and inadequate performance.
We suggest you choose from nVidia’s workstation cards instead, such as the Quadro DCC or the Quadro 2 family (Pro, MXR, EX) which are much better suited to highend 3D packages such as Maya.”
my 2 bits.
I use a FireGL1 and a Geforce2GTS and must say: without the softquadro-patch the FireGL1 clearly wins the game. However, this dramatically changes when you apply the softquadro-patch. Then the Geforce2GTS will be a lot faster than the FireGL1 and will also have working overlay-planes in most situation. Only the imageplanes will be very slow, but there is a script on highend that fixes this, too. The only thing I couldn
pls, post results 4 firegl1 on maya-testcenter.
there arent any
I
the renderer is the main thing that has dramatically improved.
The difference in the workflow if negligible, so run the test regardless.
