Geforce 6800gt Revisions
Hello all
In loooking at all my options for various upgrades I have been reading more about the Geforce 6800GT. Many people seem to recommend it if a decent Quadro is out of the question or if the computer will be used only partially for 3D. So its seems to be a reasonable choice if the price is right. From what I understand 6800 class boards are the last that can be softmodded (rivatuner?) to make more Quadro-like features available. Except that it will not work with newer revisions.
Some things I have read suggest that the AGP version can be used with rivatuner because it is first revision (NV40?) only, but PCI-e is a little trickier. For example, the GT will work but XT will not. Im sure AGP8x will work fine for me but it does lock me out of many other options. That is unless all 6800GTs can be modded regardless of revision, in which case I think PCI-e would be the best. Is this the case?
Thanks
QUOTE(SamIam39 @ 04/29/07, 09:56 PM) [snapback]265104[/snapback]
Softmodding does not really give you any significant benefit, so its actually better to gat a state of the art consumer card instead then try o get quaddro behaviors by force. Its also not a good idea to ge at a cheap old quadro versus a new consumer card.
Reason is the chip set generation, always get the highet generation you can. And if your money don’t permit a quadro then yoru not really doing 3d seriously. (because if you work on 3d the display card wont cost you penny anyway since you can draw it of in tax breaks)
The only reason not to get quadro and working on 3d sis if yoru doing ONLY lowpoly games modells and need to run the game engine in parallel to your development
