I’m currently in the market for a system to run Maya and other 3D apps. In my searches I have found that the Athlon really does give you the bigger bang for the buck. But I need to find out how the GeForce works with the K7. Does anyone have any “hands-on” experience with the compatability between the K7 and the GeForce?
The combination works wonderfully,
it works best with the kx133 chipset (like the k7v).
I had an old motherboard (a msi 6167) and it worked great until I added a miro dc30+ video capture card to it. The k7v is probably the most stable system that I’ve ever owned, even with using it for video and 3d in the same system.
Geforce works great with Athlon. Be sure to get the k7V board, I used to own a k7m board and had horrible experience with it. When I changed to the k7V board, all problems were solved, you could clock the k7v to 119 megahertz and it will still be super stable.
What exactly were your horrible experiences? I have a K7M, 750 Athlon, and Asus 6800 geforce … and I can’t get it to boot past the “Starting Windows 98” and even less with Windows 2000! I can throw in an ancient S3 PCI card, or an AGP Nvidia Vanta and everything’s fine…but not with the geforce (which worked fine for a month before not allowing the system to finish booting).
Is there anything I can check before I throw in the towel and change to the K7V?
Here are two sites that will tell you everything that you need to know about the geforce and athlon combination.
They have really helped me in the past, so thank you to the webmasters of these sites.
http://members.prestige.net/geforce/home.htm
http://www.tweak3d.net/faq/
