Hello all,
I am fairly new to Maya (Suprise!). Having worked in XSI and 3DSmax a fair amount, I'm curious how the workflow for modeling/texturing/animating works in Maya.
Specific Example: In Max and XSI you work on the lowpoly model and basically toggle the level of Sub divisions on the model. Therefore, You wieght the low poly model to the skeleton, then turn on the smoothing as needed. Maya has this proxy method of working which has me a bit confused. Do I wieght the Lowpoly to a skeleton, then convert to Sub-D? Convert to Sub-D then weight the proxy to the skeleton?
If anyone could clear this up for me it'd be greatly appriciated. (online resources on this topic?) Thanks ![]()
-Joel
