How can I get all of the shaders/materials from a single mesh?
We have 2 scenarios:
1. mesh can have a single shader/material
2. mesh can have multiple shaders/materials (due to combining nodes).
This is what we do to get a single shader from a mesh
def GetShaderFromMesh (mesh):
future = mayaCmd.listHistory(str(mesh), f=1, pdo=1)
if future is None:
return None
# Search for the connecting shading group
for n in future:
if mayaCmd.attributeQuery("surfaceShader",node=n, exists=True):
# Get shader from incoming connection of the shading group
shader = mayaCmd.listConnections("%s.surfaceShader" % (str(n)), source=True)
if shader is None:
continue
shader = str(shader[0])
return None
Thanks in advance!
oh python.... this is actually my special subject
but in python??!!? ... well lets have a look.
here a mel example:
global proc string[] getShaders(string $input[])
string $shaders[];
// shaders can be attached to shapes even if not on a face!
// so get only the faces
string $faces[] = polyListComponentConversion("-tf",$input);
if (!size($faces)) // break if there are no faces
return $shaders;
// now list all shadinggroups that these faces are members of
string $connectedSGs[] = listSets -type 1 -object $faces;
if (!size($connectedSGs)) // break if there are no shadingGroups
return $shaders;
// type lambert would not return shaders that
// aren't derived from lambert1, ls -materials works better
$shaders = ls("-materials",(listConnections -s 1 -d 0 $connectedSGs));
return $shaders;
now listHistory works well. but for example: If you select all faces of a poly object and then assign a different shader, you'd get the old shadingGroup too! Even if its not connected to any surface.
As well as the surfaceShader plug is good. Thats the common case.. but what about a volumeShader? ls -materials would get any shaders and you can parse an array! Thats the key I guess :]
Oh wow, thanks! Does this work for the scenario when a material is added to the whole object?
QUOTE(Overdrive D @ 02/14/08, 01:25 AM) [snapback]281057[/snapback]
Yes! absolutely :]
Hi to all, I finded this but i need of a reverse script,select all mesh with same material without use "hyperShade -objects " command.
Can you help me?
