Does anyone know of a way to get rid of the "requires" command that gets imbedded in files that once had a node from a specific plugin. for example if you had a scene that at one point render man, you will get a nagging "requires mtor" error every time you open the scene in maya that does not have the render man.
The only solution I could come up with is saving as .ma file and then manualy deleting the requires command.
We've been having issues with this... seeing as how some of us are in Unlimited, and some are in Complete. Part of the problem is what you suggested Gmask, but other seem to really be embedded in the file, out of the scope of editing an .asii (and how that is possible, I dunno). I found a pretty hacky workaround, but hey, it works. Change my licence from Unlimited to Complete. Wrote a script that would go through every Maya file in a dir, open, and save. It would give an error on open, but after it was saved, was quite happy in it's new form. Reset my licence back to Unlimited, and everything good. Hack hack hack...
