Getting unwanted side faces upon face extrusion
Hi. I am getting annoying “side faces” created on certain polygon extrusions involving multiple faces.
For example, create a default polygon grid with 10 sections and select a group of the center faces and extrude downward. You will notice that “side faces” are create for each quad leaving doubled polygons in the center of the “hole” you extruded rather than just at the edge of the entire group extruded. It is kind of a pain to have to individually delete these after each extrude.
does anyone know if there is a way around this that I might have overlooked?
thanks
Do you have Keep New faces together enabled under Polygons->Tool Options
you fixed it!
thanks!
