I’m trying to create a ghost shader or x-ray shader like the one in Maya for MentalRay(Maya). I not getting the desired output. The inner regions of the object to transparent and the outer opaque. It would be great if someone can give some tips on this. If there is a link also please provide it.
you should be able to use the same setup as in software render. Connection the facing racio of a sampler info to the vCoord of a ramp, and then that into the color/ambientcolor/incandescence of a shader.
The ghost shader is working in maya only.Thanks to Vladimir Jankijevic for doing it in XSI. I got the shader called dl3d_xraytexture by David Lanier from Highend3d. For avoiding the inner transparent faces.
Connect this texture to the front of a mib_two_sided shader in Maya MR.
To the back connect a mib_transparency.
Now assign this to any shading group in maya.
Now assign the shader to the object you want to render.
It works and its pretty simple. Please do check and lets discuss if there is any other problem in it.
But i’m just facing a problem with shadow, coz’ the shadow is opaque. Any suggestions.
Why didnt you just open the shpe for the object and uchek 2sided? its exxacly the same thing. Imean its much less work for the rederer too since those faces are culled away.
