Global Illumination Workflow advice
I'm using GI (photon maps) for the first time. I'm trying to create a photorealistic room with the usual stuff and furnitures etc.
I want to know what people think is the best workflow for this whilst using GI. What i mean is, do you prefer to use maya software rendering (cos its quicker) to roughly set the lighting and textures first and then, once everything is completed, to then us GI and then fine tune the lighting and texture?
Or would you prefer to use GI throughout the lighting and texturing process even though it take ages to do each test render?
Would switching from software to mental ray rendering result in two completly different images that its not advisable to switch?
Design texturing first worry about lightning second. Besides doing a low quality values down cranked gi render isnt that slow i mean i usaly get them ready in 30 secs or less. even a minute isnt so bad.
Throwing gi at your scene in a brute force fashion is just stupid. Do it in separate pass - and in this pass try to estimate which details won't contribute to overall gi effect ( e.g. shadows, bump maps etc. ) and get rid of them.
This can speed up rendering a lot, especialy if you are doing production quality animation.
If I understand you correctly Failure, are you implying that i should render shadows, bump maps seperatly and then a pass with GI lighting and superimpose them together? I thought shadows would be affected by GI (ie looks softer, might be less visiable etc) adn therefore the composite will look wrong?
Joojaa, textures would be affected by the lighting. So do you texture objects with a basic lighting setup (and using maya software rendering to see the results cos its quicker) and then set up GI once all the objects have been textured?
Look (or the shader in fact) is affected by lightning not the textures themselves. Anyway One reason i have a dual opteron workstation is that i can abuse the renderer so much i can actualy calc the gi with acceptable accuracy in test renders (offcourse i usualy crank it up a bit later).
Cache your photon solutions. and render only small subsets of the final scene (theres no need to render the entire city if your only interested in one wall of the city), but remeber hide them form raytracing etc too.
One other way would be to render out the gi and lightning on pure white and then render a testrender of textures colors only and multiply the results in photoshop or something for a PRETTY accurate version.
Altough mostly you just go with using your minds eye, its is the key here.
PS. by definition textures are maps for porperties of a shader and dont terribly much contribute to the lighted look except maybe for color bleed. What you porbably are talking about is a mixixng of terms shader and texture. Unless your coregraphing reflections but then you should use common sense more or less.
