Global variables and
Hi All Guys,
in my mel script i have a global variable, it is a string array initialize with some values.
this variable is declared and initialized at the beginning pof the script and then it's used by a procedure.
The second time i run the script i get the varning:
"Global variable is already initialized; this occurrence is ignored".
What can i do in order to eliminate this warning?
thank you very much
Daniela
Hey,
I guess you mainly want to prevent this warning for cleanliness because I don't think it will interrupt the functionality of your script.
I'm not sure what you mean by intialize.. do you mean using the clear command?
Here's a sample of what I would do and it doesn't produce such an error.
global string $test[];
clear $test;
$test=ls;
printls;
proc printls(){
for($node in $test)
print $node;
g
Hi Adrian,
well you'r right..it's not an error and my progam still goes on, but i don't want to get such warning...
initialized ... well i have something like this:
global string $text[]={
"Hi, Adrian",
"how, are, you"
then
global proc print()
global string $text[];
i've tried adding the clear command but it doesn't work...
bye
daniela
I think the problem is that you are declaring and assigning values to the variable at the same time. Declare that variable and then assign a value to it.
$text=ls -sl;
Instead of:
global string $text[]=ls -sl;
g
