There is a render shader for glow. Just go to the rendering dialog. Select MR, then options. Hit select on shaders. In the SI_Shader_Lib you shoudl see a directory for glow. Then select Edit, at the top of the shader dialog, use select to specify which object gets the shader applied to it.
Hope this helps,
Urp
