Good Detail Without Slow Performance
Hi,
I need to see in my perspective view port a closer look to the final render but all my lights and some materials like noises did not appear in the view port and it appear if I used a high quality render but it make working with Maya very slow.
I need something in between, view good detail without slow performance
Please advice,
Thanks
Or please suggest a fast render plugin for Maya
Thanks
Well, thing is theres no tricks or shortcuts for this. Rendering is computationally intensive and to make faster renders you must know what your doing. You can only speed up so much stuff without coming to terms with the realities of life. Theres quite a lot you could accelerate, but in order to do so you will need to know what your ready to sacrifice in return.
You can literary pour all the meoney in the world into this and STILL not be stisfied with the speed. its a question of expectations.On the other hand this is a question of setting up the right values too so if you turn the quality slider up you also turn your render times up.
See theres no trick in making your computer crash, eat all your memory. Or compute stupid cycles. Thing is its just something we all deal with. Which is why serious 3d production houses have literary hundreds and hundreds of computers just so they can make the snuff ready.
So how is your scene set up.
PS: theres only so much you gain form changing renderers if you cant cope with mr you cant cope with other renderers. The higher end renderers get harder to use for every step.
ok I understand your point, but I still need a fast render plugin I heard turtle is fast , what do you think ?
Well... yes and no. Its actually really hard to beat mr in speed in many areas. Something like turtle is a one trick optimized renderer, like so many others. Turtle is optimized for final gathering. Thing is however even WITH that optimization its NOT that much faster. MR is actually very fast at ray tracing.
thing is you can MAYBE get 25-30% faster performance by changing renderers, that said its a performance slider you win some you losse some. Even then its mostly about smarter factory settings. On the other hand you get easily a 50%-90% boost by economizing on what you know in any renderer and here flexinbility rules so some renderers cant get thet economizing at all.
Thing is theres just way too much going on in each scene to amke a deecent factory setting thet ALLWAYS succeeds speed optimally.
If you seriously are in business for a good RENDERER and think mr is rubish (it isnt its about the best your money can get, id rate it second or third best), get prman 13.5, but then youll be needing a exporter, im not so keen on rps but its quuite good for certain things. However if you think mr is complex then wait till you see the prman. Also the global lighting sheme of prman isnt entirely trivial to get into.
Sufficent to say no matter what you choose GI is slow!
Appreciate your advice
Thanks
