hi,
need some help regarding my graphic card for maya system. somebody pls advice me.
my system configuration-
motherboard-- asus p5-n- 32-sli.
pros-- pentium d 3.4 ghz.
ram-- 1gb * 3(total 3 gb) of transcend 667.
hd 1-- western digital 74gb(10,000 rpm).
hd 2-- segate 160 gb(7,200 rpm).
chasis-- vip zb01 with 500w smps.
monitor-- viewsonic 19" lcd- vx922( 2ms (milli second) colour scale).
graphic card-- Nvidia geforce sli -6600 gt-.
please suggest me if I should install another geforce sli 6600 card(so, total will be 2(sli)), or should I install a Nvidia Quadro fx 3500 graphic card. will 3500(Quadro) perform much faster than 2*6600(geforce).
most of the time I’ll be working on maya,photoshop,a.effects etc.
so which one suites me better.
can u pls explain in breif the difference between both( is the basic defference, the time they take to render?).cos if the diff is not major, I’ll go with 6600, as its cheaper and its working fine with me so far.
thank you.
if you do this professionally, definetely go with Quadro 3500.
although you’ve been have with FX6600 gaming card, adding another FX6600 to do SLI will take you to a different driver. not sure if you will have no issues. SLI driver is not as robust as regular nVidia driver. since FX6600 is cheap, you can always buy one and try it out. 3500 x1 won’t be significantly faster than 6600 x2, just more stable. but again if you have no issues, save the money.
hi,
thank you very much for your immediate response.
As you said 3500 is more stable than 2*6600, you mean to say that it helps to handle heavy files?
or
supports more complex options like dynamics, hair and fur?
or
it also helps in rendering quicker?
Is this wat you mean to say stable is? or any other specific advantage?
One newer, faster graphics card is usually faster than two old graphics cards using SLI–this depends on the exact cards, but in gaming terms, a single 8800 game card (currently the fastest) will usually outperform any other two Nvidia game cards in SLI. A new 8800 will cost a lot more than a second 6600 of course. But SLI really has the most benefit for gamers that already have top of the line and want a little more.
I am not up-to-date enough with Quadros to answer all your questions, but my impression is that the main benefit is that some the more advanced features in Maya (and other 3D programs) will all preview properly while you are working. With a gaming card you may get messy screen artifacts using certain tools, that will make it hard to see what you are doing. If you want to use these advanced features a Quadro is worth the extra money. If you just want to do fairly simple polygonal modeling (as I do) a game card is usually OK.
Graphics cards are designed to do “on the fly” renders to keep up with what the 3D user (or gamer) is currently doing with the program. For most renders, the software is in charge of making the image, not the hardware. Rendering speed in most cases is determined more by RAM and CPU than by the graphics card. The main exception that I know of is that certain types of particle effects in Maya can be rendered using the hardware. This is another place where a Quadro would probably be better–Maya hardware rendering is reputedly very fussy about what kind of hardware you have.
So a faster card in general (game or quadro) will help speed things up when you are working on heavy files, and neither will help much when you are rendering (unless you are hardware rendering certain particle effects, when you would be better off with a Quadro).
Now, how important are drivers. I mean, updating them. Because, the cd which I got while purchasing my g.card(6600 geforce) has some drivers for instalation. And it’s(g.card) working fine. Now should I upgrade to some other driver, as its 4 months old? will that give more performence for MAYA? Is the drivers support, for the hardware or software( I mean, does each software need different drivers?). pls reply. I have very little knowledge abt these drivers.
thank you.
