global proc initCurves() {
string $originalCrvs[] = `ls -sl`;
IntersectCurves;
CutCurves;
printOutConnections($originalCrvs);
global proc printOutConnections(string[] $sel) {
//convert selection from curve node to curveShape node
string $cvs[] = `ls -dag -leaf $sel`;
string $connections1[];
//loop thourgh all of the curveShape nodes
for($i=0; $i<size($cvs); $i++) {
//print current cuvreShape node
print($cvs[$i] + "\n");
clear($connections1);
//collect all curveIntersect nodes that are connected to current curveShape node
$connections1 = `listConnections -source 1 -destination 1 -type curveIntersect $cvs[$i]`;
for($c=0; $c<size($connections1); $c++) {
print("\t" + $connections1[$c] + "\n");
print("\t\t"); print(`listConnections -source 1 -destination 0 -plugs 0 ($connections1[$c] + ".inputCurve1")`);
print("\t\t"); print(`listConnections -source 1 -destination 0 -plugs 0 ($connections1[$c] + ".inputCurve2")`);
print("\n");
print("\n");
initCurves();
So analizing this script, looping through the 3 orignal curves prior cuttinng: are curveShape27, curveShape28, curveShape29. To make better sense out of this, curveShape27 and curveShape28 are the 2 curves that create the "T" intersection. Here is a diagram below that shows that curveShape27 and curveShape28 have the same intersecting node called, curveIntersect2. In addition, when analizing by selecting curve27 in the outliner and then curve28 in the outliner, I saw that curve27 is the top->left->leg of the "T" and curve28 is the bottom->leg of the "T". Therefore, curve27DetachedShape2 is the curve, which was not in the original list of curves created in the process when the intersected curves where cut into pieces; leaving it the top->right->leg of the "T"
Now this all sounds great on paper, but I am having a bit of troubles interpeting this into MEL. Any ideas
