If you're using POPs (the particle editor), then you can put down a Property POP and in the Particle Scale field, write an expression which indexes $AGE (or $LIFE). Another way would be to use a Color POP and put $LIFE into the index and think of the ramp representing size over age, and then in a Property POP, swap a color channel (e.g red - $CR) into the particle scale.
