Ok, so I'm totally a n00b at programming but I understand the basic concepts (more in python than mel). I'm trying to create a simple gui for the command line plugin m2mdd. However, there are several flags that are needed for the plugin to work in a way that's actually helpful. Some of those flags being -fps, (self explanatory), -sclm (scale) and -edirp (output dir).
What I'm trying to do is create a simple gui that allows me to type in the desired fps, output dir and scale and have it plug those values into the right flags.
I'm having 2 notable problems (Here's where the noobness comes in).
1) How do I grab the text that's typed into a textField and assign it to a variable?
2) How do I use that variable within the button -command function?
syntax aside, I THINK it would work something like this:
textField: "scale"
[typed value]: ".01"
textField: "OutputDir"
$scale = scale.value
$outdir = OutputDir.value
button -command "m2mdd -edirp$outdir -sclm$scale"
resulting in the equivilent of typing "m2mdd-edirp C:/... -sclm .01" into the mel command line.
Clearly my syntax is all off but that's basically what I'm trying to get at.
Help please?
-David
