Hair Is Offset When Object Is Moved
Here is my dilema:
I have this bee thats ha shair. When I scale/rotate/move the parent node
, the object moves but the hair seems the go offset..
I do have them parented but I am at a loss.
Im am running Maya 7 on a OSx v10.4.5.
here is a jpg of what is happening:
http://gmanxl.com/tmp/BEE\_hairlink.jpg
Any info will be much appreciated. I am new to this forum-btw.
Thanks
Well in order to make suggestions so as how to fix this, you might wanna inform us a bit more about the setup of your hairSystem, like perhaps where the follicles are, what is parented to what? I’m afraid not much can be said from the Outliner window you have there.
If you wanted to change the Start Position of you hair curves you can go Hair > Set Start Position > From Current.
hello,
i have the same problem, although i used paint effects for the hair. i’m making a human head.
my paint effect stokes are parented to the object, but when i move the object (head), the paint effect storkes (hair) won’t move with it. ugh. can anyone help me?
thanks,
If this is like it looks a doubletrasform. move the dynamicaluy linked things ito a soparate group.
thanks a lot! i just fixed the problem.
i separated/unparented the strokes from the object, and i just parented the control curves to the object. the storkes were set to the curves using the curve utility.
ugh, i’m having the same offsetting problem again.
i separated the paint fx (hair) from other groups, and it worked at first for some strange reason.
after separating the paint fx elements, i parented the paint fx to one of the joints in my model. i tried parenting it to the polygon mesh, parent contrainting, and not parenting it at all. none of them worked.
how can i avoid the double transform problem, and at the same time, parent the paint fx elemets to the model? can anyone help me?
