Having problems with Mental ray global illum
The docs dont seem show me how to assign an attribute for enabling global illum in maya. I followed the directions but it tells me to look under the “mental ray” tab in the attribute editor…the thing is not there! Can anyone help?
E
Turning global illumination on is under the mental ray globals menu. Select previewGlobalIllumination in the drop down menu.
If you are referring to the tabs in the attribute editor, select your object and look under its transform node in the attribute editor (first tab I beilieve) you will see a mental ray menu, allowing you to set the objects to be receivers or transmitters for GI and caustics etc, or to use default settings derived from Maya.
In the shape node for the lights, you will find another extra mental ray tab for adjusting GI photons, energy etc.
Hope that helps
Ben L
Also, you can not emit photons from standard maya area lights (which don’t have mental ray tab) - you need to use directional, spot or point lights (which you can set as Mray area lights if you need)
