Having Technical Problems With Maya 2009
The above image shows what happens randomly when im trying to model things. When i first had the problem i just assumed it was a bug or something with maya but it seems to be happening more recently. So my best guess is that is my graphics card. Any help or input is greatly appreciated.
Comp Specs:
Windows xp 32 bit
AMD Phenom 3.0 quadcore
4 gig's of ram
nvidia 9600.
Hope that helps!
QUOTE(extirpate @ 08/12/09, 03:27 AM) [snapback]312976[/snapback]
Yep your card is not supported so theres no grantee it will work. There only 2 things you can do, either get a new gfx card OR try different driver versions even older than the one you have now.*
*Newer gfx card driver does not equate to a better driver, it just equates to better optimized driver for top 10 games. Wich is not equal to better driver. It usually fixes the problem but there's no guarantee it will. Now because your card is not supported nobody will tell you WHAT exact driver will do the trick so you can newer know until you've tested them all whether or not this problem is solvable.
