Having trouble with this basic shape in NURBS
I want to make a basic table with rounded corners. The problems I have are that I can't figure out how to fill in the surface of the table top without using a trim.
Here's how I have tried it:
for the sides, I draw the curve for the border (a rectangle with rounded corners) and then dupe it, and loft it. Now I have the side of the table.
My problem is the TOP and BOTTOM. The would be planes with rounded corners. I could just take the border curve and do a planar trim across it, but I want to stay away from trims. Is there another way?
(Sorry I would have just posted a pic of the shape, but I my web page account won't work.)
Its going to take alot of work to do this without trims with nurbs. What is your reason for not using trims? Unless you are going to animate the table to be an organic character then it isn't really a big deal using trims.
Another option would be to build the object with trims and if the surfaces are the proper shape(4 sided) then you can just use "Trim Convert" in the rebuild menu.
Why not cut up the top curve into 4 different curves, and then make a boundary/square surface?
Or duplicate the topmost isoparam and scale it to a point (you bettr insert a additional isoparam ner tha center, to better avoid a problem with nurbs poles)then loft and/or maye also attach with the original surface. (but the square can be better, or then just split up and loft opposite corners)
