Hi. I am trying to render out an image into a floating point color .tif image (RGBfloat/ RGBAfloat under mental ray framebuffer settings).
Problem is, this image’s gamma comes out way brighter in the output file then the render appears in the renderwindow. The default “gamma” setting is at 1.0 which I assume is the problem.
Does anyone know which gamma setting variable I need to use to make it match my PC?
thanks
