Hdr To .map Exe
how do i do the conversion do i need to load dos then run it or jus drag the pic of over the the exe cuse if i do that nothing happens? thanks guys
If its the one I'm thinking of , you had to run it through DOS
nitpicky:
DOS = windows command prompt. Wich resembles dos only in appearance. Its still windows not dos
dos is fine / do i direct myslef to the exe in dos then what?hat is the syntax thanks guys
