Hello. I am what you would call a newbie to Combustion 3. I have my movie all made and ready, put it in combustion, I have the particle effects on the video. But, when I go to render it, it renders, then when I play the video after rendering, it seems like the Frames Per Second was cut in half. My setting were the usual 29.97 FPS, and all the other "default" settings. When I play the video in WinAmp, the bar down at the bottom is saying many different varations of my FPS. it ranges from 20 FPS to 36 FPS sometimes. But in the end, it moves with skips. It almost seems like frames were dropped or taken out of the video. (I did not render video to RAM). If you need more information, I'll glady give it too you. [I used almost all the codecs I have on all of their settings, still the same]
Thank you, please get back, I'm anxious to see how the "real video" came out. (I have the project saved as a workspace, so i wont have to restart it every time, even though i might have wrong settings in it causing the problems, even though they are all normal. )
