To add a little more. You can tag points and use the tag option to reduce differently on various portions of the model.
For instance if you had a model of vase, you could reduce the sides tremdously, and still maintain the same basic shape. However, if you reduced the lip of the vase by the same amount, you would loose most of it. So, doing each portion seperately lets you reduce where you need it most.
Urp
